You don't need an ICV, your problem is the tune forg
If you don't have an ICV then your idle will be dependant on 2 things, 1 is the idle function on the ecu (fuel, ignition) and 2 is the little screw on the TB which should adjust your idle?
So yes I imagine at least "some" air needs to get through the TB regardless
