Wondering if anyone has any schematics showing particularly the lines to/from the reservoir and to/from the pump. Undoubtedly the factory WS manual would have it, but would prefer an electronic version.
dont have a diagram but i can quickly explain most of it as i just converted mine.
resevoir goes to rack.
resevoir goes under radiator to pump supply(big one that fits on with hose clamp).
pump screw in fitting goes under motor to rack.
they are different sizes from memory so i dont think you can put them in the wrong place.
Thanks. I'm looking at re-locating the PS reservoir on my R31 Skyline to give more room for a conversion. I suspect the line that goes under the radiator is the pump supply, but I really need to know exactly where it runs.....looks like a trip to a wreckers might be required.
