As part of my quest to make my car less stealable, I want to put in a hidden switch for the electronic pump thats in the boot.
Basically the pump is earthed out on the body and has a + wire running to the coil (I did not do this, but hey, works ok)
What I plan to do is intercept this wire and put a switch under the dash so that I can cut the power to the pump, no pump, no fuel, no go.
to stop the switch coping the full load from the battery, what should I do, and from a safety aspect I'm also guessing I should put a fuse in as well.
Ideas people?
Ideas people?
