CFM of carby
    CFM of carby
    hi guys
    how r u all ???
    i was just wonderin if anyone knows what CFM the carby on a series 2 nissan bluebird is (it has a Nissan L20B engine in it)
    n if theres a higher CFM carby i can put on it without havin to changin manifolds
    Get it to wheel spin uncontrollably then give it another 10 pounds boost
    Life begins at 30 PSI
    More cfm than the engine can use.
    Originally posted by bugle
    The non GTS's were gay
      dont know what cfm the bluebird carb is, but you should be able to change the carb to a weber or a holley by using an adaptor plate. You can get them for around $60 from autobarn. As for how much CFM the car can use, it shouldnt really matter as long as you dont go to small, too big will just cause it to bog down or idle rough, but as long as you dont go TOO big, these problems shouldnt be a problem
      Originally posted by TRD-RT81
      would not care as long as when i fucked her my balls did not touch matt damon's
      Originally posted by MR 1JZ
      lara bingle is a fucking dropkick slut with a nice set of tits
