ok the sr 20 is going in the cefiro turbo is a trust t518z z32 afm 550 injectors gtr cooler etc.
now I 'm wondering whether its worth while doing a camshaft upgrade thinking 256 or 264's. not the 272's.
who has fitted aftermarket cams and can tell me results.
the concensus that my tuner has come up with is its not worth doing unless you have abuilt motor ie head work etc and want to rev it 9000 and want to put a big top mount turbo ex gated turbo.
my thoughts are there will be gains in the mid to top range.
my personal thought is that factory cams are pretty retarded cause they have to meet emmissions so they can't be agressive. so I was thinking the cams to add some more oompp to the car and if I can reduce the boost from say 1.2 bar to 1 bar to make the same power that would be good.
the car will have most of the good gear and the motor will be built when this one dies. but I'm looking to now rather than down the track. rev limit will be 7500 on the motor for now with very occasional 8000 rpm. I would fit a lash killer kit if nessacary
am I dreaming?
meggala
am I dreaming?
meggala
