CV band/clamp sizing
    I need to replace a clamp on the outer CV joint on my 4wd but I've got NFI how these things are sized.
    Looking on the Tridon site, they stock from 130mm up to 680mm. I'm assuming this is the length of the band when flat, so I'd need to work out the circumference of the CV boot, then buy one which has a bit of overlap.
    Is there a rule of thumb with how much extra length I should have? Or is it better to just go way oversized and cut off all the excess?
