Bmw getrag 260 is it the same as a commodore 260 getrag??
    I have a e30 and I'm looking for a 260 getrag gearbox and I keep seeing commodore getrag 260 gearbox's, question is do they fit. Guessing it's got a different bell housing etc?? Anyone
    Been a few years since looking at them v8 box has slip yoke & external speed sensor whereas v6 is opposite with coupling & different bellhousing obviously.
    Most likely different 1st gear ratio
    Put vs v8 getrag into lc torrie 10 plus years ago....t5 more common/easier
      Commodore getrags are different at least from the important stuff ie bellhousing. I thought the ratios are the same at least from the reference I recall seeing. You would probably be aware that the M20 bellhousing pattern is different from the M30 bellhousing.
        i've got some form of 260 here i believe, i think with m30 bellhousing pattern
