Best way to remove Carbon from valves?
    Currently doing valve stem seals and noticed the valves have a lot of carbon build up around them, just wondering what is the best way to clean them up without damaging them?
    Thanks
ID:	7077209Click image for larger version
    Soak em in Brake Cleaner then give em a hit with a wire brush.
      Oven cleaner.
      Originally posted by brewdles
        Thanks will try those suggestions when I get home from work. Wire brush on drill or just by hand?
        Are those scotch brite pads that you use on the 90 degree die grinder any good or will they do damage?
          Bench grinder with wire buff. Gone in 60 sec
            Bead blasting is how I did mine.
              oil and place in 88deg preheated engine
              set timer for 2hrs
              adjust throttle to 8000rpm
              open beer
              turn after 1 hr
              finish beer.
              remove valves and serve
                Piranha solution
                Originally posted by Marlin
                  Wire wheel on the bench grinder, gone in a flash and if fucks the hardened valve then you know they were shit anyway
                    Wire wheel on bench grinder.
                      I know this is kind of left field, but I think a wire wheel on a bench grinder might be the go.
                      Oo___oO
                        Couldn't you use a bench grinder for this? With a wire wheel.
                          Or maybe a bench wheel with a wire grinder will take the carbon off the valves?
                            Soak them in methanol.
                              Ended up using the wire wheel on the bench grinder along with some brake cleaner and oven cleaner, cannot believe this wasn't suggested!
                              Anyway happy with the way things turned out, actually came off quite easily.
                              Thanks all for the advice
ID:	7078262Click image for larger version
