What bolt is this?
    What bolt is this?
    Is an automotive fastening bolt.. From my untrained eye appears to be a m10 (10mm thread diameter).. 1.25 pitch and 35mm?? Or is it "superfine" (1.00) ? I think it may be a "dog point bolt" ?? Basically I need the same except another 10-15mm in length. Where is a good place to buy such a thing?
    Click image for larger version  Name:	IMG_20200209_210224841.jpg Views:	0 Size:	2.86 MB ID:	7112146
    your former friendly cambodian dictator
    If you need the captive washers, the best place to get one would be a Japanese car wrecker.
      Could be from a seat or seatbelt
      If in doubt, flat out!
        ^ close.. this bolt held in a bracket that used to hold the rear-most set of seats (that I have now removed). I don't think I really need the washers.. have many at home that I can use.. Is not really for anything too serious, just to fasten something to a 4WD floor, so now need a bit more length.
        I have gone through my "assorted collection" of random automotive bolts, but unfortunately they are all about the same length
          yeah that would be M10 fine thread.
          Misumi will have them with captive washer.
            a decent bolt place should sort you out then. where are you?
              Brisbane.. but can wait a week or so for delivery.
                Try here: https://www.unitedfasteners.com.au/ (at Darra)
                don't ask to ride my bike and i won't ask if i can shag your missus
                  I’ve always found m10 and m11 x 1.0mm bolts hard to get as they’re most commonly seatbelt related, the bolt places don’t supply them. That said, I’ve never tried All that hard as a wrecker is just as easy, but still...
                    I found many fastener shops here useless for oddball stuff. I ended up going to http://www.Accu.co.uk they had what I wanted in stock.
                      Pretty sure seatbelt bolts are UNF.
                      Originally posted by brewdles
                        Yup. Even in Toyota's.
                          There are also metric ones around now just to confuse the situation - m10x1.5 from memory
                            When is the transition?
                            Pretty sure all the Toyota ones I've seen from the late 80's onwards have been M10x1.25
