AN brake booster hose and check valve?
    G'day blokes, I would like to run a -6 hose for my brake booster vac line, I can put a -6 weld on, onto the brake booster pipe , however I can't seem to find a one way check valve that will accept AN fittings ( only barb types), a female threaded valve would be ideal, so I can screw some suitable fittings into.
    On another note, I've seen the billet push into grommet fittings for commodores that have a -6 machines on them, what do they run for a check valve?
    Ta
    CL valiant sedan 245 3 speed
    VH dodge utility 215 3 speed, project/ trailer puller
    74 chrysler lancer LA sedan, 2.6 EFI turbo, 230kw
    chrysler galant sedan, daily
    chrysler galant coupe- long term project
    mitsubishi starion turbo, cutties, front lip, scrapes and smashes on everything
    I’m using one of these
    https://speedflow.com.au/non-return-valves-from/
    -6 is a bit small imo
      https://www.ebay.com.au/itm/PROFLOW-...QAAOSw4uhcge9P
      List of cars goes here
        Does anyone make something like that in a threaded form, rather than a push in fitting.
          What do you mean?
          Aluminum automotive fitting selections are pretty poor, you can buy a BSPT>JIC 90deg fitting pretty easily.
          Same deal with the check valve, just buy a 1/2" BSP check valve and you can use whatever AN fittings you want.
            Originally posted by dnegative View Post
            What do you mean?
            More like an integrated one way valve within a banjo bolt. Long shot really, but worth a try.
              I doubt it, theres no need for it !
                Yeah, its a bit of an anomaly, but heaps of the time i come across stuff that there doesnt seem to be any need for and yet gets produced.
