Turbos - can they cause milkshakes?
    Hai guys, the nopics volvo C30 has milkshaked itself in a serious way. Its pumped a litre of oil into the cooling system on a 1hr ish drive. No coolant in the oil though.
    Ill be pressure testing the oil cooler as close to operating temps as i can (cold test passed), but i was also wondering if the turbo could potentially be the culprit? Its the next easiest thing to get at before rage quit time.
    TIA cunts!
    Does it have a water/oil trans cooler. Has been known to happen on falcons with zf that have water/oil coolers.
      I guess it could come from the turbo, pretty unlikely though. Relatively easy to check at least, remove and block coolant lines to turbo, drive . . .
        I’d be checking the oil/water heat exchanger
          Very unlikely you will have enough pressure in the turbo cartridge to pump into the cooling system. Most likely a failed heat exchanger or seal/gasket somewhere.
            Volvo = heat gasket. 5 cylinder?
              If it's not the oil cooler module, it'll be the HG.
              Originally posted by brewdles
                Did you say 1 more psi before turning the boost controller 1 more click?
                  Most of the time its the radiator. The trans cooler part leaks into the coolant part. Often a shagged trans is the outcome. A lot of brands had a recall for it, nissan, mecedes etc
                  Sent from my SM-N960N using Tapatalk
