Any easy/cheap ways of improving the fuel economy of a 4 litre Ford EL Falcon?
    bozz bozz bozz /meggala shakes his head.
    buy a barina if you want economy :D
    doruiod thecams sounds likea good idea.
    but any way if you want to check a/f figures next time your at sams stick his meter up the exhaust pipe :D
    btw the economy sounds pretty good to me.
    cheers
    check out my web site
    http://meggala.com
    yeah I tow cars and other things
      I also reckon the econ that you are getting now is pretty damn good. I only wish the manual EL had a similar top gear ratio as the auto. BTW the EL has a 68L Fuel tank, Pretty sure its been that way since the EA, but the EL is notorious for "gagging" early when you try to fill it right up. Kinda like women...
      as an example, an elephant pushes over a tree to eat the fresh leaves at the top, but a human isnt allowed to build a machine that makes a car so he can drive around to places quicker?
        Would it be possible at part throttle to feed the ECU a constant 1/2 volt signal so that it "thinks" the engines running at stoich, but modify the airflow sensor signal to run it leaner?
        To add to what jmac said about lean a/f ratios, I was looking at some aircraft sites a while ago & a couple of them had some nice graphs plotting exhaust temps against a/f ratio, peak temps actually occurred at about stoich 14.7:1, running leaner actually drops the temperature as does running richer. Why... when you run lean you are burning less fuel therefore you generate less heat, & when you run rich the excess fuel has a cooling effect.
        -Mahatma Gandhi
        Indian independence leader
