Fittings for high vibration environments (offroad) speedflow or brass barbs?
    Hi All,
    doing a diesel fuel system for an offroader that will see a lot of ruts in its life. its 12mm low pressure hose and i need to get it into a 1/4 NPT fitting for a filter assembly. I may well be over thinking this.
    options are
    - brass 1/4"NPT to 12mm hose barb with a clamp (which is turning out to be impossible to find)
    - speedflow 1/4"NPT to male -8 taper then -8 female taper to 12mm hose barb with a clamp
    in aircraft and shit they always seem to lockwire the AN fittings. do they ever come loose? or does Aluminium thread gall enough to hold? i guess the other option is a dab of loctite on the speedflow taper joint threads.
    Oo___oO
    They don't gal at all in my experience, I have never seen an issue, there is a few guys that work on these all the time, Allan's engineering in malalla tune some and also Troy from TeeZee tuning does them, U could ask them.
    I would suggest you are overthinking and just put on dash fitting and move on.
    3D scanning
    3D modelling
    Structural certification
    3 and 5 axis milling
      https://australia.dixonvalve.com/product/1020804SS
      Originally posted by Marlin
        Yeah, go with some sort of steel product.
        JIC/AN fittings dont come loose with vibration either.
          From memory a couple of the Adelaide guys who ran big offroad rigs were using stainless JIC fittings rather than alloy AN ones.
