Swapping aircon compressor types??
    Gents,
    I have a vehicle which is currently running a Sanden TRS090 3015. It has about 20psi pressure differential across the suction and discharge sides, indicating the pump is kaput. I would like to adapt a BA falcon compressor seeing as they aren't covered in lumps and bumps like every other compressor and they are stacked ten high at the wrecker rather than being over $700 from overseas.
    The aircon has an adjustable thermostat to control what temp the compressor kicks in and out at. If I can get the thing to fit and get some hoses made up is there anything that could go horribly wrong with this idea?
    No, should be fine.
      Originally posted by dnegative View Post
      No, should be fine.
      Cheers mate I'll give it a crack.
        Unless you wanted a genuine brand new Sanden SD7H15 which I happen to have for sale for $350 + shipping.
