Radiator Upgraded needed......
    If you are going to have to fark around & recore/relocate pipes etc then just go the PWR route. I put one in the BA, its huge & cost about $600. For that, in my mind its not worth rooting around. Your relocate/ducting idea sounds good provided my brain is understanding it correctly.
    Of course I could do you a deal on a new std BA radiator but I dont think its worthwhile.
      beat me to it
        Thanks edo.....but no thanks. I am just waiting on an email back from PWR atthe moment.....edo, can you tell me what measurements they require etc? Can they add brackets to the top to locate the radiator?
        Go Hard..........or Go Home!
        VW Amarok - Daily
        2001 S15 - IPRA Build
        VE SS Redline Ute - SOLD
          Mark, my FJ now has a 88 degree C thermostat, up from 84, the idea was to run it a bit hotter for better efficiency. I don't see a problem with running constantly in the mid 90's or even a touch more on occasions.
          Agree with the airflow points made here, can make a big difference.
          ― Jim C. Hines
          ― Daniel Patrick Moynihan
          ― Napoleon Bonaparte
            Where are the outlets on the radiator? top and bottom drivers side?
            R31 skyline radiator is reasonably good, however plastic tanks, but the inlout/outlet are the top and bottom of the drivers side...Just an idea, probably in the wrong places I spose...
            - Phil Ken Sebben
              I wish to clarify my comments about thermos. I hate them and that's that. I know they only make a difference at walking pace.
              I just wanted you to know that I hate thermos. That is all.
              Regards
              Thermo Hater
              PS Did I mention I hate thermos..
                Originally posted by Bitsamissing
                Changing to a lower opening thermostat wont pull the temp down if it's already exceeding the current thermostat.
                Worked on mine.
                How & when is the thermo coming on ? Looks like you could fit a bigger one in there
                U could right
                  Thanks for the input Floody.....drivers side top....passneger side bottom.
                  Big Muz...I have a thermo i use on the race....did you want to buy it? Perfect workig order You just a Motec toi tell it when to come on
                  Cheers guys.....It won't be replaced before The Datsun Nationals....but we should be ok for that.....I will address the problem after Easter.
                  VW Amarok - Daily
                    Datman, give them as many dimensions as you can, basically pull your old one out & measure it. Add a bit here & there where there is room & add thickness to it as well. You can specify where you want the mounting brackets/tabs.
                      datman - i had a gemini that had overheating probs cause of heavy modifications, i managed to find a Holden HK TG radiator and this thing fitted all most perfect, just got the hose fitting locations swapped from left to right($10) and drilled 4 new mounting holes($free)... worked 100% picked up the radiator for $90 from wreckers in great nick. and fitted 2x 12 inch davies craig thermo's.
                      Might be an idea to check one out(i just took a tape measure along to wreckers), i would imagine the dato and gemi engne bay size wouldnt be to much differnet.(might be a really cheap option !! )
                      Cheers
                      EFI82
                      Suicide Racing Member
                      AE90 Corolla 4AGZE
                      MY99 Subaru GT Forester 2.2 Stroker
                      84 Holden Gemini 4ZC1-T
                        Don't forget that you've also got the option of putting a high pressure radiator cap on. (If you haven't already).
                        Just don't do it with plastic end tanks :O
                          Regards
                          Thermo Hater
                          Its good to know there is another person who has the same opinion as me.
                          Lets form a cult.
                          Originally posted by paul05
                            Datman: So what exactly do you plan to do regarding the small factory cutout for the radiator? I'm thinking you'll need to put some carefull thought into ducting (as you said) and maybe a sort of under tray (as Bill S had suggested).
                            The rest of ya: See attached pic of my sunny to get an idea of the size (height is roughly the same as the width).
                              Lets form a cult.
                              I too am a member of this cult. I am a huge fan of engine fans though...
                                I name us 'Cult of the Clutch Fan Fans'
                                I have seen so many overheating problems caused by electric water pumps and thermos. If the clutch works correctly the fan will cause bugger all addititonal load on the engine, and will suck an enormous amount of air through the rad. I reckon a good fan will still help cool up to maybe 20 kays or even more. Certainly will be better than some big thermo blocking airflow all the time.
                                Muz
