OK, I have an oldish motor with a mechanical pump. On hot days or long undriven periods the fuel likes to evaporate out of the carby despite having a carb spacer.
This means that when I come to start it up again sometimes it can take a while to crank over enough fuel to start up.
I'm looking to hook up an electric pump to replace the mechanical one, but I don't really want a holley as I've heard theyre horribly noisy. Also if possible I'd like to avoid having to run return fuel lines.
Suggestions? Quiet, external, carb pressure (up to 6-12psi or so), enough fuel to supply to a 600cfm carb.
