I got rid of the baja bug, and replaced it with a manx buggy. Was out caning the arse off it on stockton on the weekend, having the best fun! All weekend it was a total bastard to start, getting worse as the day went on. Finally it started to cough and backfire and miss under revs (load didn't seem to be the problem).
Limped it home and went through the usual replacing with new stuff in the following order:
Points,
condenser,
plugs,
leads (incl bakelite ends),
check fuel filter,
check dwell and timing.
There's fuel in the carb, and the fuel pump seems ok, no torn diaphragms or other leaks or damage, seems to pump up fine too.
Still ran like a turd. Then checked:
Carby for crap in the jet or bowl (spotless),
swapped out spare dizzy, cap and rotor button.
Nothing appears to have an effect! This is the first time in a decade a motor has beaten me! I'm totally out of ideas on this bastard!
Any suggestions? No I won't burn it, and no it's NOT a fucking tumour!!
Points,
condenser,
plugs,
check fuel filter,
