Hi Guys.
My head specialist has advised me if i want to make descent power i should convert to solid lifters, thats fine but. i have a set of tomei 260 degree 8.8mm lift cams. am i able to use these lobe type cams with a solid lifter conversion? (i already have the valve springs for the solid lifters just need to get the shims and solid type lifters.)
If this is not possible to use these does anyone want to buy a set of drop in replacment tomei cams for the ca18det $600? brand new still in the box.
Thanks
Neil
Thanks
Neil
so far 11.5 - 123 mph
