I disagree with some of the thought expressed above. This has its own trigger and is not connected in anyway to the oil light. It is intended as a pre oiler as noted but is also intended to address the issues of starvation of the pump (I would agree that the longterm fix is a better sump) when other fixes are not possible or too expensive e.g. short-track bitumen events where dry sumps are illegal. The flow from the 3 qt model will provide the pressure that it is stored at and the triggering pressure is set by the installer. Thus it can trigger at 30-20-10PSI. Personally I would run one in addition to a well baffled sump. Think of it as more an added 3-4 seconds to see the big low oil pressure warning light!
BTW the SAE state that 70% of engine wear occurs at startup they are naturally good for that
