I've been removing the sound deadner on my Lancer recently, the only way I could get it off was to get it hot and running then scrape off. I have thrown out two buckets full of re-hardened sound deadner so far. To get the last bits off, I have been using a wire brush on a drill and eucalyptus oil, smelly and messy, but it is working.
I tapped from underneath the car on the floorpan a few times which cracked it, then I just peeled it all away
1300's have a massive sheet of the stuff layered on the floor and trans tunnel and it was melting from the heat of the rotary exhaust.
Originally posted by Stix Z
