Car wont run.
    Okay, this:
    Originally posted by Jason_g200t
    the car runs perfectly some times, but breaks down with spluttering and then randomly decideds to splutter, run good or not fire at all.
    is a hell of a lot different to this:
    Im getting spark but the car keeps cutting out and when it does run its only for a few seconds and very roughly.
    you have a loose wire or dodgey connection somewhere. Check all the wires and pins in the ECU connector are pushed firmly into the connector.
      Okay ill do go try that shortly.
      Jason Broadhurst
        I have pulled out the loom and checked every wire, and I could not find any problems with joints or breaks..
        I will get some fittings for my pressure gauge and check the fuel pressure today, before i send my ECU to haltech to have it bench tested.
        Jason Broadhurst
          car wont run
          mate just thought id give u a helping hand its def the ecu the same happened to my charade detomaso it burnt a component in the circuit board if u put a wire from the negative of the battery to the fuel pump relay (inside fuse box under the bonnet) it will let the car run until u get a new ecu.
            Thanks for the help, it did all seem to point to the ECU, however it was the coil having too low a resistance for the ignitor to function properly.
            Changed coil and its now running great and I have finnished tuning it.
            Jason Broadhurst
