Haltech Tune Issues
    Its common for mixtures to change fairly drastically like yours is doing depends on cam intake manifold etc. You will have to fiddle with the mixtures till the bucking goes away and live with the rich mixtures at some point. I would start with the 1500rpm site.
    You can NEVER have enough Horse Power
      Really its that common? The carbi used to run a 14:1 from idle to 7000 on primarys and it didn't have a problem. The bucking did go away with a 12:1 on both 1500 and 2000 rpm ranges but that cant be a genuine fix?
      Jason Broadhurst
        do you have any data logs from the haltech when you were having trouble?
        Donate and save 3 lives - http://www.arcbs.redcross.org.au/
          [QUOTE]Really its that common? The carbi used to run a 14:1 from idle to 7000 on primarys and it didn't have a problem. The bucking did go away with a 12:1 on both 1500 and 2000 rpm ranges but that cant be a genuine fix?
          [/QUOTE
          You probbaly have fairly different numbers in the 2 maps at that point when you move off the dead centre of each speed range the processor starts intoperlating the values.
          In your case halfway is more than likely a number not suitable for whats happening in the motor.
          How big is the jump in your injection values between the 1500 map and the 2000 map? What is happening with your ign timing at that point?
            "Justin Wangburner"! How the fuck did you get that nickname!? :D
              I dont know, and as bad as it is, I only dont like it because people might mistake me for you :p
              Jason Broadhurst
                my tuner had to redo a few haltech looms because of interfierence for exact reason.
                3D scanning
                3D modelling
                Structural certification
                3 and 5 axis milling
                  should interference show up on a data log though?
                  Jason Broadhurst
                    Alright, it seems ECU specific. When I remove spark from each cylinder it still gets worse between 1500-2000 rpm.
                    http://turbocharade.kicks-ass.org/fi...%20datalog.xls
                    http://turbocharade.kicks-ass.org/files/RPM-log.TXT
                    The spreadsheet is of the rpm and inj duty, showing roughness at the area in question.
                    The TXT is the raw data from the haltech.
                    Jason Broadhurst
                      Yes it should show up as a weird reading. I noticed a few of these when tuning evilchief's liberty.
                      It looks to me that the trigger signal is not working very well. I am guessing you were trying to accelerate not create the spikes. This could happen because of the ignition, trigger wire or the haltech
                        It does seem that there is a small inconsistancy in the rpm. The trigger is negative earth, and it is unclear whether the rough rpm logging is the cause or just the symptom of a fault in the ignition.
                        Oddly, if I run a fat mixture, the problem goes away, but anything over 13:1 and it is there. The more it heads towards stoich, the more prominant the problem.
                        What do you lads think? I am going to have to get a CRO on it I think.
                        Jason Broadhurst
                          Jason: I have a CRO sitting at my parents place you can have (for the forseeable fututre anyway). Gimme a call if you want it.
                            The jumping rpm is a symptom on the datalog, because the car is bucking around it logs rpm inconsistantly.
                            I threw a analyser on it and the tach feed was perfect.
                            Time to consider ignition problems then.
                            Jason Broadhurst
                              What injector timing values are you using? If they change drastically around that rpm point that may be the cause of your problem?
                              Originally posted by jmac
                              But on seatbelts - I don't think they should be mandatory for adults, but for under 18s. I reckon make them mandatory up till then, and provide plenty of graphic evidence supporting their use to school age children, and then if they hit adulthood and don't choose to wear them, think of the future without these fucken idiots around...
                                They are consistant durring the problem, as the graph/logs show.
                                Jason Broadhurst
