Did your MA have the separate trans computer?
Modding the A340LE transmission
Ring MV autos in Adelaide and order a shift box for $195.
Then read this
http://toymods.net/forums/showthread...ht=autos+shift
Then whack it in
Done.state street drift champion 2003
Formerly known as bassaholic55
Wouldn't it be piss easy to make your own controler once you know which solenoids do what?10.83 @ 125
Originally posted by crackaSome conclusions empirically were that a large protruding ridge like a prolapsed arsehole around the runner was largely beneficial.
what is tiptronic?
The one I have is fully manualised. Just change the gear shifter and gear changes. Is tiptronic different to that?
Dennis: probably if you knew a bit about electronics.
You basically just need an input signal and it will either have to switch A, A&B or just B. I am sure for electronically minded people it would be easy but certainly not for me!state street drift champion 2003
Not if you don't know how to program microcontrollers, or have the facilities to do so.Originally posted by 2JZR31Wouldn't it be piss easy to make your own controler once you know which solenoids do what?
Bass
Tiptronic is where you push a button to change gears. ie press the up change button to go up a gear or push the down button to go down a gear.Never argue with an idiot. They will bring you down to their level and beat you with experience.
yeah like paddles or push buttons on the wheelOriginally posted by bassaholic55what is tiptronic?
manualised I gather means it doesn't shift by itself any more or more correctly, you gain manual but you chosen to give up auto shifting?
I reckon the market for tiptronic would be pretty limited amongst enthusiasts given there are only 4 gears and it's a bit of a wank anyway on factory systemsOriginally posted by boxxx
Your best option is to swap the ECU for an auto one. I'm sure there are plenty of 1JZ owners doing a manual conversion who would be happy to swap.Originally posted by AzzA351hey just wondering what you guys think i should do i just got a 30-40LE auto trans for my 1jz-gte into ma61 supra, the 1jz waz from a manual jza70 frontcut so has the manual ecu (didnt come with box) how and what would i do to get the auto running-working....my ma61 was auto.
Better yet, get an R154 and forget this whole auto nonsense.Norbie!
I just tried this today. You seem to be correct in the what solenoids do. Earlier in the thread some of us were not sure this was correct because the other diagrams for boxes with less solenoids had a SLN which could only have been for the converter. Seems Toyota has no consistency there!Originally posted by KDogS1 - shift solenoid
S2 - shift solenoid
SLN - accumulator pressure solenoid
SLU - Torque Lockup solenoid (found on 1uzfe trans etc)
SLT - the line pressure solenoid.
You can leave the SLN solenoid disconnected. It will give quicker shifts.
Leaving SLT disconnected may provide both firmer/faster shifts, i have never fiddled with one to find out.
The 2jzge should have the S1, S2 and SLU (not SLN) doesn't it?
I chopped the SLU, and the converter no longer hooked up.
I chopped the SLN (accumulator I think), I didn't really notice much.
I chopped the SLT and the shifts got much quicker and firmer at partial throttle. But I believe a full throttle its no different, which is where it counts. Its conceivable that at full throttle the ECU maxes these pressures out anyway?
I was going to make a controller to manipulate the solenoids, but I doubt its going to be better. Reason being that with a chopped wire, the duty cycle would be 0%. And no controller can give less than that! (assuming 0% duty cycle gives the firmest and fastest shifts, which chopping the wires seems to have shown.
Comments?10.83 @ 125
Yep, thats what I am saying.Originally posted by bassaholic55Makes sense to me. So you are saying that the ecu would have already operated those solenoids to the best of their ability and it cannot be improved upon using the device you were planning on using.10.83 @ 125
Do you know which one the line pressure reg is? I posted shitloads of pics in the first post in this thread of the valve body. Can anyone identify it?. I would like to know which solenoids are which.10.83 @ 125
