Cheapest brake rotors! Fast delivery!
    Originally posted by Aaron View Post
    RDyno, the Penrite 310 degree stuff used to be available from Autopro in Tuggers, Same price as GSL, but obviously local. It could be worth giving them a call if you need it in a hurry.
    Na it's all good I found the cap off my master after 3 months but tested it and it came in at 230 deg so ill let it sit for awhile but when I need some more ill ask gsl as my supplier is dearer.
      hey mate, can you get old valiant discs.
      After some solid discs from VE/VF and ventilated discs from a VG valiant (101.7mm pcd).
        Hey mate, sorry for the really late reply.
        I can get the front disks no dramas for $100 inc gst each, but know one has any listing for any rears.
        Regards Matt
        Brakes Direct
          ONLY A FEW KITS LEFT!
          This deal won't be repeated, and was only a one off bulk purchase of the TNF rotors! The R33 GTS-T kit there's still a bit of stock left, but the rest are down to low single digit quantities!
          Get in quick to avoid missing out, order online at http://gslrallysport.com/au/brakes/v...-packages.html or give us a call, 1300 884 836!
          Brakes Direct
            Regards Matt
            That's alright I missed the reply.
            So which ones can you get, both styles?
              What do you mean by styles? It may be easier if you wana give me a call to work it out.
              Regards Matt
              Brakes Direct
                Bought some more stuff off the guys last week. Painless experience as always. Cheers for the Rotors and Pads Matt.
                  All good mate
                  Brakes Direct
                    Can you get me a price for a set of rotors and pads for all 4 wheels for a non turbo 300zx just for street use.
                    I can't find your thread on Aus300zx anymore.
                    You don't sell caliper rebuild kits do you?
                    Thanks.
                      Thanks.
                      Hi,
                      Are you after slotted rotors or just plain rotors?
                      Regards Matt
                      Brakes Direct
                        Just plain.
                        Edit: Actually, could you give me prices for both?
                        Thanks
                        Hi,
                        Regards Matt
                          Just plain.
                          Thanks
                          Hi,
                          The pads I would recommend are the QFM HPX pads, these are like an equivalent to a Bendix Ultimate in terms of performance as they are both rated to 550 degrees, but the QFM's don't come with any of the downsides of the Bendix like high dust and rotor wear. I can supply these for $79 inc gst per set front or rear.
                          As for the rotors, i can supply RDA standards for $74 inc gst per front rotor and $63 inc gst per rear rotor. And RDA Dark Series slotted and dimpled rotors for $220 inc gst for the front pair and $198 inc gst for the rear pair.
                          The easiest way to order is credit card over the phone, 1300 884 836, or else swing me your full name, email address, delivery address (preferably a work or business address!!) and contact number and I can fire you through an quote with direct deposit details.
                          Also if you need brake fluid, the fluid that we use and recommend is the TRW RBF600 Dot 4 Racing Brake Fluid, which is $59 for a 1L bottle, and rated to 312 degrees dry. One bottle is usually enough for a full car flush.
                          If you have any other questions, please don’t hesitate to ask.
                          Regards Matt
                          Brakes Direct
                            http://youtu.be/5OWM1wttWA8
                            GSL RallySport & Brakes Direct's technical director Greg Latham explains which way slotted rotors are supposed to turn, and dispels a lot of the myths behind this!
                            For more information contact Brakes Direct:
                            http://www.brakesdirect.com.au/ - Brakes Direct is your complete brake parts specialist! From trade, commercial, prestige, 4WD, fleet, performance and competition!
                            • Aus: 1300 724 943
                            • NZ: 09 951 5726
                            Brakes Direct
                              Can you guys get Golf Mk5 front rotors & pads?
                                Thanks, PM on it's way.
