Hook step seal rings (power transmission) similar to piston rings
    Wanted Hook step seal rings (power transmission) similar to piston rings
    Gentlemans I need to find someone who can get me a hook step seal ring (see pic). I've got two on the back of the PTO clutch assy in my old tractor which have cracked and need replacing. It's a blind install so must use a hook step type ring, no room to get in and compress the ring as it's being installed. The rings are approx 74mm diameter but can get exact measurements when I find a supplier. I've tried genuine parts but they no longer exist and all of the industrial seal and bearing places in Townsville have said they have NFI. :knock:
    Older auto transmissions use these, rebuild kits usually do away with the metal in favor of plastic
    http://www.phoenixpistonrings.com.au/products
    List of cars goes here
      Not sure if you are still looking for this but, sounds (couldnt open the pics) similar to whats used in CAT auto gearbags. If you can get some sizes i can see what i have at work.
