Irs packages... Thought bubble
    Pfft, bottle of gas & a spool of wire for the welder, some cutting discs, some rhs and some sheetmetal - it's only expensive if you pay someone to do it for you.
    #lifemotto lol :D
    Sent from my HTC_0P6B using Tapatalk
    06/07/2011
      Fuck sorry for the cursive ...
      06/07/2011
        I would be, so it would be
        Fantapants, would require new strut towers, bracing and mounting to chassis etc, it *should* be much less intensive than something like the s13 since the whole setup is fairly square and self contained (which is why I am considering it) but it's still a lot of work
          Just had a look at some Google imaging #eyeverniersaredialledin and I recon you would go very close with using the stock shock location as coilovers with a bit of strengthening of you really wanted. But if it's anything like the ae86 rear shock towers there is plenty of meat to hold the body weight. I've run rear xoilovers there for over 10 years with no sign of the hats even separating. Obviously a hard driving style you might want extra support for price of mind :D
          But I need to prove I can do it to mine before I start convincing people it really easy for them lol
          06/07/2011
            Looking at pictures of the hubs, I don't think they aren't going to take well to either welding and redrilling or rotating 45 degrees. There isn't a lot of meat in there...
              What sort of shoddy dodginess is it to redrill the wheels for a multifit? I have google imaged the back of the wheel face and it looks like they only have the full width of meat in the current drillings... Clocking the wheels 45 leaves the back face hollowed out...
              06/07/2011
                Originally posted by fantapants View Post
                I'm using coilovers at the rear so after a quick look there I not much in the way of doing something like this. Would take a bit of reworking of the lower inside of the wheel well and there might be clearance issues with the handbrake mechanism on disc brakes...
                piece of piss mate :D
                  Hahha totally : D
                  06/07/2011
                    This bloke transplanted most of an MX5 under his Datsun 520 pickup :http://community.ratsun.net/topic/74...20-top-secret/
                      thankls for all the tips and advice guys
                      can someone help walk me through roll centres and stuff in terms of settling the cradle at the height i want to run looking to match front roll centres i guess
                      06/07/2011
                        The traditional rule of thumb is the lower wishbones should be close to horizontal. Without sitting down and reading a bunch of texts and spending a few hours crunching numbers in cad/excel/susprog3d, aim to install the mx5 rear end at it's stock (or slightly lowered) ride height. It'll be close enough, and you can tune the handling balance with springs and bars.
                          Awesome that's what I was working on.
                          I'll get under the car and figure out the angles on the lca at the front then look at trying to match the roll centres roughly to that by using the flat at ride height method lol
                          06/07/2011
                            I think I have a spare pair of 1.8 ABS 4-stud hubs still in a crate in the garage. Will grab pics - but Ben might be right and the thickness varies - being thicker where the wheel studs are pressed through.
                            276mm rear rotors as per 2001-2005 NB should fit under the 15s. Otherwise the ~250mm setup will.
                              I've had a chat with my old boss about rewelding and redrilling and he is confidant we can do it easily enough. So I'll probably go that way. Is there something special about the whole for the spline to bed into or just a sligty smaller size jammed the fuck ? Lol
                              06/07/2011
                                If you mean stud holes there's nothing special. Small hole with splined stud as you'd expect.
