Opinions needed
    Opinions needed
    Got hold of a 2nd hand but unused brake conversion kit for my mk2 Cortina but have run into a problem with fitment
    The disc is touching the the LCA, Im amusing this wouldn't be an issue if I were using the oem LCA/balljoint arrangement
    Its not touching by much but touching none the less, Im thinking about spacing out the hub (about 3mm) by either a spacer between the rear bearing and the stub or between the bearing cup and hub then having the fron bearing cup machined deeper into the hub!
    Can anyone see any problems with this, and if so whats another way to skin this ?
    List of cars goes here
    bit more neg camber ?
      what does the hub/disk assembly look like?
        Could you shave the face of the LCA?
        Keep in mind the clearance may change between full bump and full droop.
          Start by pulling the caplier off and stacking some spacers between the hub face and the hat. Move it through the full range of motion, lock to lock and full bump to full droop. It may be easier to do this with the spring removed. If that looks OK, pack the caliper out with some washers and reassemble to make sure everything clears. Obviously don't drive it with the temporary spacers in place.
          Make sure you have enough thread engagement on the wheel nuts. Then get proper spacers made up for the rotor and caliper.
            Cheers
            Yeah have already been through those steps when the problem presented itself, just unsure on the best solution
            I did consider a spacer between hub and rotor but it will move the rotor off the center
              Its at its worst at full droop and just clears at ride height
              I think if i were to remove material from the lca to gain enough clearance i may run the risk of exposing the bearing
                Originally posted by Gassed250 View Post
                Cheers
                If it's only a few mm it shouldn't be a problem. It's not unusual for custom brake/rotor setups to have a different centreline to stock.
                  Sorry i should have been clearer
                  What i mean by "off the center" is the center bore of the disc will no longer sit on the hub
                  Spacing the disc off the hub would definitely be the easiest option
                    What i mean by "off the center" is the center bore of the disc will no longer sit on the hub. Spacing the disc off the hub would definitely be the easiest option
                    You could bore out the centre of the disk, and make a spacer with a register on it to locate on the hub and into the new bore of the disk. You could even have another step on the spacer to locate the wheel.
                    Originally posted by Marlin
                      Or you could just not worry about perfectly centring the rotor and rely on the studs. Has worked for me in the past on various race cars without issue.
                        Had another look, the disc still locates on the hub with 3mm spacers so its looking good
                        Question is how much disc to lca clearance do I need ?
                          It will get bigger over time..
                            Ha ha ha!
                            But to answer the question Gassed, I would think you would want a few mm if putting it on the track, things tend to flex more than you would believe when fully loaded up. If it's a road car, not so much clearance, but if the LCA touches the rotor occasionally, no biggie, refer to 36's comment above.
                              I ended up spacing the entire hub out by 4mm as the bearing seal was sitting back too far
