Brake fluid life
    Brake fluid life
    Because I didn't know how much fluid I'd need for my brake-master replacement, I bought 4 x 500mL of it.
    These are Castrol bottles of slightly-better-than-standard, "React Performance" DOT 4 (ie. not the Racing stuff that's 2.5x the price).
    Only used 1L, so have two unopened bottles (manufactured April 2019).
    How long should I keep them?
    Untill you need to use some brake fluid again.
      Brake fluid flush approx every 2 years, assuming I continue to not-punish it as much as I have thus far; so itís got a >2yr shelf-life?
      I suspected it might not last that long, given all the Stuff you read about using fresh brake fluid.
        Dot 4 deteriorates from exposure to moisture in the air. If you keep the sealed they should be fine for road car use after 2 years.
        If you want to be really paranoid, put the unopened bottles in a sealed plastic bag with some silica gel sachets.
          Thanks Sprinkles.
            the bottles are sealed (foil seal under the cap), indefinite shelf life.
            once opened then the clock starts ticking.
            GT-P
            Bandsenkowagon
              These hadn't been opened (the plastic ring was still attached to the lid, & made the 'crack' sound when opened), but these Castrol bottles don't have a foil seal attached to the top of the bottle. They just seal with the lid; I'm guessing it's compromised when you first crack it open.
                Well, if you cracked the lid open, and screwed it up tight, it's probably still ok for 12 months or more. It's not like it's sitting open to the elements.
                  Thread bump... I got a 4L bottle on the cheap and what I did not only screwing it tight is to get a cheap Daiso vacuum bag and wrapping the bottle in it. Been almost a year and it's holding tight with no leakage.
