Remote boosters
    Remote boosters
    I've converted my mk2 cortina to 4 wheel disc
    VE Commodore front/EL Falcon rear, i have a Wilwood dual mc and an adjustable proportioning valve
    now the mk2 never came with boosted brakes and theres no room on or behind the firewall to fit a conventional booster so the only option is VHxx of some sort
    I've had nothing to do with these and have no idea what i need for a 4wd set up, all the units I've seen are either drum or disc/drum
    school me
    List of cars goes here
    Shirley it stops close enough to the tyre limits now, does it need a booster?
    Is your new M.C. single or dual circuit?
    If dual then what is the sit?
      Yes MC is dual circuit and tyres are 205-225 15 nankang AR-1
      Im not sure if the system actually needs a booster but im sure it wouldnt hurt to have and I dont want to find out it was a "should of done" thing after I plumb the brakes or get caught out when its time to engineer
      Id prefer to keep things clean and simple and not have a booster but id also like to play it safe
        Spoke to a brake bloke about something similar for the 2002. They have a shitty remote dual booster set up. I am considering doing away with it and may be going to rear discs. Internet 'folklore' say remove the boosters, use a smaller master cylinder and redrill the brake pedal to change the pedal ratio slightly. I may use a VH44 on the front circuit for some additional assistance.
        My thought was try it without then if additional assistance is required plumb in a VH44.
          Ask your engineer now.
          Even if you are happy with a firm pedal, NCOP has a maximum force limit for the application of the brakes.
            Yep
            Then you need master size , caliper piston sizes and pedal ratios to know where to start on the 2 boosters you will need
              Can you use the escort style booster or will it not fit the cortina?
