VS Statesman - lowering
    Hi all,
    Chasing ideas that need to meet the following
    - lower than standard
    - retain legal ride height
    - retain comfort to some degree
    - not bank breaking
    Thanks
      Get them heated up & reset would give the results you want...no idea on price or who to go to tbh.
      Other option maybe 2nd set of pedders/lovellls as they seem to have had nicer ride comfort.Didn't like king springs
        Facebook marketplace a set of so front and ssl rears for IRS commodore.
        VT-VZ springs will sit a touch higher than VR/VS because VR/VS were lighter.
        off the top of my head, VR/VS Statesman and VT-VZ rears are same part number, as similar weight.
        VS-VZ fronts are same part number throughout (v6 & v8 respectively)
        v6 springs will sit lower in a v8, v8 springs higher in a v6 etc.....
          You'll want to look at rear camber/toe kits if you go much lower than stock
            FE2 if you can find them.
            Subtly lower, minimal (if any) increase in spring rate. After trying a bunch of stuff I ended up with FE2 in the WK, paired with Koni Adjustables it handles really well (for an overweight barge that is).
              king springs SLs and some monroes. it's just a fancy commodore, no need to overcomplicate it
              Originally posted by Mr Jones
              Farmer its all about how you cut them up, like a dead hooker jigsaw puzzle.
                Hehehe memories.
                  I am a bit beyond that sort of shit tbh.
                    https://www.ebay.com.au/itm/160777289979?ul_noapp=true
                    This looks the goods I'd say.
                    Probably just wait for the next ebay % off sale.
                      the code Prince200 will get you $50 off that price now if that helps
                        Had FE2s in my VR with KYB Excel-Gs for an SS in the front, and Excel-G SS ute shocks in the rear. Rode decent for a daily, without the bouncy bullshit that everyone else seems to have when they lower a Commodore.
                        Originally posted by brewdles
                          You'll be disappointed.
                          sl front and ssl rear, events it out, respectable low but still legal,shocks and struts are a good thing and make all the comfort didfernce
                            Hmmm do I wait 4 days and save $600?
                            Not too fussed on even - but has to be legal. Any idea on the exact height it would end up at with SL front and SSL rear?
                              SL would be about 25mm lower than fe2 or 50mm lower than stocker springs....SL on rear will sit 25-40mm higher than front hence most get lower for back.
                              Wait 4 days spend coin saved on memcal or shiftkit + servo
