Spacers to return back to stock position
    Whilst we know that spacers to move wheels out from standard offset is a no-no, but are spacers OK for rims that have too much positive offset to move the position back to stock position? Would this be a defectable mod?
    bolt on or slip on? what's the difference in offset that we're talking?
      10mm. Would be avoiding bolt on for the sake of 10mm but that's probably beyond limit of the studs for safe operation.
        The biggest concern would be if you have enough thread engagement on the studs with the 10mm spacers fitted. You might need to fit longer studs, in which case it would be safe (I run 20mm spacers on the front of the track car). I can't comment on the legality.
          Didnt think it mattered as you werent allowed anything between the wheel and hub flanges that wasnt oem supplied.
          The track increase thing and returning it to the same position as factory is a seperate issue.
            I believe not.
            Hopefully I don't get to find out with the old barge I have with 25mm bolt on spacers to shift the the sweet 80's spec wheels out to where they should be.
              Yes. But unlikely to happen.
