Hi all.
Just bought a VF1 Calais V. I think it goes around corners remarkably well for how comfy the the ride is, but it's a bit soggy and understeery.
I'm looking for a nicer turn in, a little bit less floaty-ness and a bit more tail-happiness.
I really don't want to lower it, I think it looks ok as is and I'm over dragging the exhaust system on Bunnings speed humps like I've been doing for a decade in my old VX.
From what I can work out, FE1,2 and 3 all use the same springs.
Obviously therefore damping rates are quite different, and the sway bars are quite different too. The Calais has 24mm on the front and a little 13mm on the rear according to my measurements.
The interwebs suggest FE2 is 23mm front and 18mm rear? Redline got a much bigger rear but I think something happened with rear pickup points in the VF2 which makes it hard to compare.
So I'm thinking some more caster, maybe a bit more camber, perhaps a set of those Koni FSD shocks that Holmart have on special, and a thicker rear bar.
Suggestions? Major flaws in my thinking?
