CARROLL SMITH’S CAUSE AND EFFECT GUIDE
RIDE AND ROLL RESISTANCE-SPRING
Too much spring: overall
• Harsh and choppy ride
• Much unprovoked sliding
• Car will not put power down on corner exit – excessive wheel-spin
Relatively too much spring: front
• Understeer – although the car may initially point in well
• Front breaks loose over bumps in corners
• Front tyres lock while braking over bumps
Relatively too much spring: rear
• Oversteer immediately on application of power
• Excessive wheel-spin
Too little spring: overall
• Car contacts the track a lot
• Floating ride with excess vertical chassis movement, pitch and roll
• Sloppy and inconsistent response
• Car slow to take a set – may take more than one
Relatively too little spring: rear
• Excessive squat on acceleration accompanied by excessive rear negative camber, leading to oversteer and poor power down characteristics
• Tendency to fall over on outside rear tyre and ‘flop’ into oversteer and wheel-spin
ANTI-ROLL BARS
Too much anti-roll bar: overall
• Car will be very sudden in response and will have little feel
• Car will tend to slide or skate rather than taking a set – especially in slow and medium speed corners
• Car may dart over one wheel or diagonal bumps
Relatively too much anti-roll bar: front
• Corner entry understeer which usually becomes progressively worse as the driver tries to tighten the corner radius.
Relatively too much anti-roll bar: rear
• If the imbalance is extreme can cause corner entry oversteer
• Corner exit oversteer. Car won’t put down power but goes directly to oversteer due to inside wheel-spin
• Excessive sliding on corner exit
• Car has a violent reaction to major bumps and may be upset by ‘FIA’ kerbs
Too little anti-roll bar: overall
• Car is lazy in response, generally sloppy
• Car is reluctant to change direction in chicane and esses
Relatively too little anti-roll bar: front
• Car ‘falls over’ onto outside tyre on corner entry and then washes out into understeer
• Car is lazy in direction changes
Relatively too little anti-roll: rear
• My own opinion is that on most road courses a rear anti-roll bar is a bad thing. Anti-roll bars transfer lateral load from the unladen tyre to the laden tyre – exactly what we don’t want at the rear. I would much rather use enough spring to support the rear of the car. The exception comes when there are ‘washboard ripples’ at corner exits, as on street circuits and poorly paved road circuits.
SHOCK ABSORBER FORCES
Too much shock: overall
• A very sudden car with harsh ride qualities, much sliding and wheel patter
• Car will not absorb road surface irregularities but crashes over them
Too much rebound force
• Wheels do not return quickly to road surface after displacement. Inside wheel in a corner may be pulled off the road by the damper while still loaded
• Car may ‘jack down’ over bumps or in long corners causing a loss of tyre compliance. Car does not power down well at exit of corners when road surface is not extremely smooth
Too much bump force: general
• Harsh reaction to road surface irregularities.
• Car slides rather than sticking
• Car doesn’t put power down well - driving wheels hop.
Too much low piston speed bump force
• Car’s reaction to steering input too sudden
• Car’s reaction to lateral and longitudinal load transfer too harsh
Too much high piston speed bump force
• Car’s reaction to minor road surface irregularities too harsh – tyres hop over ‘chatter bumps’ and ripples in braking areas and corner exits.
Too little shock: overall
• Car floats a lot (the Cadillac ride syndrome) and oscillates after bumps
• Car dives and squats a lot
• Car rolls quickly in response to lateral acceleration and may tend to ‘fall over’ onto the outside front tyre during corner entry and outside rear tyre on corner exit.
• Car is generally sloppy and unresponsive
Too little rebound force: overall
• Car floats – oscillates after bumps (the Cadillac ride syndrome)
Too little bump force: overall
• Initial turn in reaction soft and sloppy
• Excessive and quick roll, dive and squat
Too little low piston speed bump force
• Car is generally imprecise and sloppy in response to lateral (and, to a lesser extent longitudinal) accelerations and to driver steering inputs
Too little high piston speed bump force
• Suspension may bottom over the largest bumps on the track resulting in momentary loss of tyre contact and excessive instantaneous loads on suspension and chassis
Dead shock on one corner
• A dead shock is surprisingly difficult for a driver to identify and/or isolate
• At the rear, that car will ‘fall over’ onto the outside tyre and oversteer in one direction only
• At the front, the car will ‘fall over’ onto the outside tyre on corner entry and then understeer.
WHEEL ALIGNMENTTYRES
Too much tyre pressure
• Harsh ride, excessive wheel patter, sliding and wheel-spin
• High temperature reading and wear at the centre of the tyre
Too little tyre pressure
• Soft and mushy response
• Reduced footprint area and reduced traction
• High temperatures with a dip in the centre of the tread
Front tyres ‘going off’
• Gradually increasing understeer – Enter corners slower, get on power earlier with less steering lock
Rear tyres ‘going off’
• Gradually increasing power on oversteer – Try to carry more speed through corner and be later and more gradual with power application
LIMITED SLIP MALADIES
Limited slip differential wearing out
• Initial symptoms are decreased power on understeer or increased power on oversteer and inside wheel spin. The car might be easier to drive, but it will be slow
• When wear becomes extreme, stability under hard acceleration from low speed will diminish and things will not be pleasant at all
Excessive cam or ramp angle on coast side plate (clutch pack) limited slip differential
• Corner entry, mid-phase and corner exit understeer. Incurable with geometry changes or rates – must change differential ramps. In 1998, virtually everyone is running 0/0 or 80/80 ramps.
SUSPENSION GEOMETRY
Excessive front scrub radius (steering offset)
• Excessive steering effort accompanied by imprecise and inconsistent ‘feel’ and feedback
Excessive roll centre lateral envelope: front or rear
• Non-linear response and feel to steering input and lateral ‘G’ (side force) generation
Rear roll centre too low (or front r/c relatively too high)
• Roll axis too far out of parallel with mass centroid axis, leading to non-linear generation of lateral load transfer and chassis roll as well as the generation of excessive front jacking force.
• Tendency will be towards understeer
Rear roll centre too high (or front r/c relatively too low)
• Opposite of above, tending towards excessive jacking at the rear and oversteer
Front track width too narrow relative to rear
• Car tends to ‘trip over its front feet’ during slow and medium speed corner entry, evidenced by lots of understeer (remember trying to turn your tricycle?)
• Crutch is to increase front ride rate and roll resistance and increase the camber curves in the direction of more negative camber in bump (usually by raising the front roll centre)
ANTI-ROLL BARS
SUSPENSION GEOMETRY
